Experience with TT AWD alignment...(lengthy)
Old Jul 23, 2003 | 05:31 AM
cher's Avatar
New Member
Default Experience with TT AWD alignment...(lengthy)
Took my 2001 225 qc into a local reputable shop near Rockford IL for new tire mounting and AWD alignment yesterday. They had quoted me $20 a tire for dismount, mount, and static balancing. They quoted me at $54.95 for AWD alignment...which is VERY reasonable. I asked them if they've done Audis before and they reassured me they've done several Audis. About 4:30 in the afternoon the shop called me and said they were unable to do the AWD alignment on my car because their manual flagged the procedure, stating they needed a special tool (which they did not have) to reset the steering sensor. They informed me that I'd have to take it to the Audi dealer for proper aligning. My dealer in Rockford is an awesome dealer, but charges $149.95 for an alignment! I then asked my shop if this special tool to reset this steering sensor was related to the ESP? He said that yes, it was. I told him no problem...mine is a very early '01 with no ESP. Unfortunately it was too late in the day to do the alignment, so I am bringing the TT back this afternoon. I guess not having ESP can also be a good thing when it comes to having alignments done. Saved myself almost $100! FYI: After doing hours and hours of researching, I purchased 4 new Wanli 225/45/17 S-1099 tires online and total cost with shipping was only $305! These tires have the same tread pattern as the Yokahamas (directional awesome V-tread), but at a fraction of the cost. I have a friend that runs these tires and he is extremely happy with their performance. I drove the TT into the Chicago area last night and then back home. I am extremely happy with their performance so far! They really grab the pavement and are very quiet. I highly recommend them. By the way, I had Michelin Pilot Sports on the TT and they were crap compared to these Wanli's.
Old Jul 23, 2003 | 05:40 AM
Kurt's Avatar
Junior Member
So, the shop just can't turn the ESP off to align the tires? That option is available.
Old Jul 23, 2003 | 06:38 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I don't understand the logic here...
An alignment is purely mechanical.
And Wanli tires?
Old Jul 23, 2003 | 06:54 AM
nikhil's Avatar
Default i'm guessing here>
but it sounds like there is a steering sensor that needs to be adjusted on ESP-enabled cars when doing an alignment...
Old Jul 23, 2003 | 07:00 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I could see that..>>
If things were way out, or a rack was replaced, but fractional angle adjustments should not affect it. This is the first this issue has surfaced, and people have been getting alignments for years!
Old Jul 23, 2003 | 07:20 AM
nikhil's Avatar
Default true>
but maybe most shops have the tool needed to adjust the sensor, while this one does not(meaning maybe it's not a TT-specific tool, but one that is needed on cars with ESP).
Old Jul 23, 2003 | 07:23 AM
KD's Avatar
KD
Wanli Truck tires??
Old Jul 23, 2003 | 08:40 AM
cher's Avatar
New Member
Default Re: I don't understand the logic here...
Wanli manufactures a wide spectrum of tires...not just truck tires. The tires I purchased are a Z rated high performance tire and the tread is an exact replica of the Yokohama AVS Sport tire.
Old Jul 23, 2003 | 04:46 PM
ooyahhh's Avatar
Junior Member
Default TT alignment is not as simple as most cars.
· Proceed to Section F
Section F - Front End alignment
· IMPORTANT - On quattro vehicles, prior to aligning the vehicle, torque the rear shock mount lower bolt to 110 Nm (81 ft. lbs.) with the wheels on the ground
· IMPORTANT - On front wheel drive vehicles, prior to aligning the vehicle, torque the rear shock absorber mounting lower bolt to 40Nm (30ft. lbs.) + an additional 900 with the wheels on the ground
· IMPORTANT - Subframe bolts must be torqued after doing the front end alignment
General Notes
Wheel alignment should only be checked using VW/Audi approved wheel alignment equipment
When making adjustments, keep to the specified settings as accurately as possible
Vibrations can also be caused by excessive residual imbalance and/or vertical wheel run out
Wheel alignment checks must always include both the front and the rear axles otherwise the proper running characteristics of the vehicle cannot be ensured
Wheel Alignment Specifications
Specifications valid for all engine versions
Front axle
Front Wheel Drive
quattro
Toe setting for each wheel (wheels not pressed)
4' + 3.5'
4' + 3.5'
Overall toe (wheels not pressed)
8' + 7'
8' + 7'
Camber 1)
- 45' + 30'
- 45' + 30'
Maximum permissible difference between left and right
Maximum 30'
Maximum 30'
Toe-out on turns at 200
- 10 31' + 20'
- 10 31' + 20'
Caster (not adjustable)
70 58' + 30'
70 58' + 30'
Maximum 30'
Maximum 30'
1) There is no provision for adjusting camber. Slight corrections cam be made by moving the subframe: adjustment range
approx 10' to 15'.
Rear axle
Front Wheel Drive
Camber 1)
-20 + 20'
Maximum 30'
Toe setting for each wheel 1)
14' + 5'
Overall toe 1)
28' + 10'
Maximum permissible deviation in direction of travel relative to axis of vehicle 2)
Maximum 15'
1) not adjustable
2) slight corrections are possible by moving the rear axle beam
Rear axle
quattro
Camber
-10 2' + 20'
Maximum 20'
7.5' + 30'
Overall toe
15' + 10'
Maximum 20'
Test Requirements
Check suspension, steering and steering linkage for excessive play and damage
Tread depth difference of no more that 2 mm on one axle
Tires are inflated to correct pressure
Vehicle at correct curb weight 1)
1) Curb weight is defined as the weight of the vehicle ready for the road (fuel tank completely filled, spare wheel, vehicle tools and vehicle jack)
After a certain period, wheel alignment platforms and computer equipment can lose their original leveling setting and adjustments
Wheel alignment platforms and computer equipment should be serviced and calibrated at least once a year
· Precision equipment of this type should be treated with due care
If necessary, contact the manufacture for familiarization with the proper use of the equipment
Note: Setting basic settings of headlight range control or the longitudinal acceleration sensor will need to be done after doing the front end alignment
Setting Wheel Alignment
Ü Use V.A.G. Electronic Alignment machine or equivalent
Ensure that the sliding plates and turntables are not touching the end stop when checking the wheel alignment
Vehicle accurately aligned, suspension bounced and rocked several times
The test equipment must be properly adjusted and attached to the vehicle (see equipment manufacturer's instructions)
Carry out wheel run-out compensation
Note: Compensating wheel run-out: The permissible lateral run-out of the wheel rims can exceed the specified toe setting tolerance. If the compensation for wheel run-out is not performed, it will not be possible to obtain a correct toe adjustment
Ü Insert brake pedal depressor
Overview of work sequence for measuring wheel alignment
The vehicle must be at curb weight when measuring wheel alignment
Use the following work sequence
Check front axle camber and center if necessary
Check rear axle camber (not adjustable)
Check rear axle toe and adjust as required
Vehicles with front wheel drive, toe is not adjustable
quattro vehicles, adjust toe as required
4. Check front axle toe with vehicle at curb weight and adjust as required
Checking rear axle camber (vehicles with front wheel drive and quattro)
The camber can be checked but not adjusted on vehicles with front wheel drive and quattro
If the readings are outside the permitted tolerances, the axle beam must be checked for damage and possibly replaced
Centering rear axle toe (vehicles with front wheel drive)
The overall toe setting on the rear axle cannot be adjusted
By moving the rear axle it is possible to center the individual toe settings
· Loosen securing bolts on mounting brackets
· Center the individual toe settings by moving the axle beam within the elongated holes at the mounting brackets
If the overall toe setting is outside the permitted tolerance, or if it is not possible to center the individual settings, the axle beam must be checked for damage and possibly replaced
It may also be necessary to check and measure the body alignment in the area of the rear axle mounting points and repair as required
Adjusting rear wheel toe (quattro vehicles)
Ü Loosen all bolts on mounting bracket -1-
Ü Move mounting bracket -1- in the direction of arrows
· Tighten bolts to 75 Nm (55 ft lbs.)
· Always use new bolts
Centering front axle camber
The camber cannot be adjusted
By moving the subframe it is possible to center the camber within the specified tolerance range
Adjusting front wheel toe
Ü Hold tie rod end -A- and loosen lock nut -B-
Ü Adjust toe on left and right hand wheels by turning tie rod at -C-
IMPORTANT - Ensure that the rubber boots are not twisted after turning the tie rods; twisted boots wear out quickly
Ü Torque lock nut -B- to 50 Nm (37 ft. Lbs.); noting that the setting may change slightly after tightening
· If the measured toe is inside the tolerance, the adjustment is correct
· Front end alignment is complete
Ü Torque subframe bolts -11- & -12- to 100 Nm (74 ft. lbs.) and turn an additional 90O
Ü Bolts -G- have already been torqued
Ü With wheels on the ground, torque control arm bolt -16- and bolt -17- with nut -10- to 70 Nm (52 ft. lbs.) and turn 90O further
Ü Torque nuts -18- to 75 Nm (55 ft. lbs.)
· If vehicle has Xenon or high intensity discharge (HID) headlights, proceed to Section G for setting the basic settings for the automatic headlight levelers
· If vehicle is a quattro, and does not have Xenon or high intensity discharge headlights, go to Section H for setting the basic settings of the longitudinal acceleration sender (G251)
· If vehicle is not a quattro and does not have Xenon headlights the recall work is completed
Section G - Setting basic settings for vehicles with automatic headlight levelers
· The basic settings can be performed on the wheel alignment platform after front end alignment with vehicle on its wheels
§ Settle car (push down on car a few times so that shock absorbers and car move up and down)
Ü With ignition switched off, connect VAS 5051 or V.A.G. 1551
· Switch ignition switch to the on position
Rapid data transfer Help Insert address word XX
Ü Indicated on display
· Push buttons -5- twice for "Headlight automatic headlight range control"
· Push Q to confirm input
4B0907357 LEUCHTWEITEREGLER D003® Coding 00010 WSC01236
· Push ® button
Rapid data transfer Help Select Function XX
· Press buttons -0- and -4- to select "Basic Setting" function
Rapid Data Transfer Help 04 - Basic Setting
· Press -Q- button to confirm input
Basic Setting Input display group number XXX
· Press buttons -0-, -0- and -1- to input display group number 001
Basic Setting 1® Please Wait
· Headlights are moved into adjustment position (about 15 seconds)
System in Basic Setting 1® Set headlights
Headlights are now in adjustment position
· Adjust headlights using a headlight adjustment tool ( e.g. VAS5046)
Basic setting 1 turns regulation off and "Headlights not adjusted" will be stored in DTC memory
· Press ® button
Rapid data transfer Help Select function XX
· Press buttons -0- and -4- to select "Basic Setting" function 04
Rapid data transfer Q 04 - Basic setting
· Press buttons -0-, -0- and -2- to input display group number 002
System in Basic Setting 2 ® ctrl. pos. learned
The control module has stored this position as the normal position. "Headlights not adjusted" is erased from DTC memory and regulation is switched back on
· Press ® button
· Press buttons -0- and -6- to select the function "End output"
· If vehicle is a quattro, proceed to Section H
· If vehicle is front wheel drive, turn ignition switch to off position and disconnect V.A.G. 1551 or VAS 5051: recall work is completed
Section H - Setting basic settings for longitudinal acceleration sender (G251) on quattro vehicles
· The basic settings can be performed on the wheel alignment platform after front end alignment with the vehicle on its wheels
Rapid data transfer Help Enter address work XX
· Press -0- and -3- buttons to select address word for "Brake electronics"
Rapid data transfer Q 03 - Brake Electronics
Rapid data transfer Scan tool sends address word 03
8N0907379 C ABS/EDS 20 IE CAN V003 ® Coding 13504 WSC XXXXX
Ü If the diagnostic link between the control unit and fault reader V.A.G. 1551 or VAS 5051 is working properly, the display will show the control unit identification
· Press ® button
Interrogating and erasing fault memory
· Push -0- and -2- buttons to select the function "Check DTC Memory"
Correct any fault stored in the memory using repair procedures
· Press ® button
· Press -0- and -5- buttons to select the function "Erase DTC Memory"
Rapid data transfer Q 05 Erase DTC memory
Rapid data transfer ® DTC memory is erased
· Press ® button
· Press button 1 twice to select function 11 "Login Procedure"
Rapid data transfer Q 11 Login-Procedure
Login procedure Help Input code number XXXXX
· Enter code number 40168
◄ Indicated on display
· Press buttons 0 and 4 to select the "Basic setting" function
I extracted this out of the MK1 to MK2 conversion. Sorry it's hard to read.
Basic setting Help Enter display group number XXX
· Press buttons -0-, -6- and -9-
· ABS warning lamp will blink
System in basic setting 69 compens. OK 0.0X m/s2
The value in the display does not go back to 0.00 m/s2 after zero compensation has been successfully completed.
· Press ® button
· Turn ignition switch to off position and remove V.A.G. 1551 or VAS 5051, recall work is completed
3/29/00
b
Old Jul 23, 2003 | 05:07 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default What a bunch of bureaucratic crap.....
Life (or alignments) are just not that complicated
