Fault code help....
P1557 - 35-00 - -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
And it's causing soft limp mode. Only change was my new hyperboost adjustable versus my old dead non adjustable hyperboost valve.
After, loosen the adjustment all the way. Then tighten after a few runs.
Do a log of blk 204. And keep track of the boost pressures of the different settings. If you tighten too far, you get a flutter when releasing the throttle/shifting.
