Fault Code Readings
Old Jun 12, 2008 | 11:37 AM
mastrpdawg's Avatar
Default Fault Code Readings
So I just purchased a $20 Ebay cable and used the Ross Tech 401.9s software to enable one touch unlock and remote windows...
I ran a complete scan for fault codes and this is what came up (of course before the uneregistered version kicked me out):
Scan 6-12-08
VAG-COM Version: Release 409.1-S
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 8N0 906 018 CJ
Component: 1.8L R4/5VT G 0001
Coding: 07710
Shop #: WSC 79672
TRUWT28N041022082 AUZ5Z0D0145022
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 H
Component: ESP ALLRAD MK60 0101
Coding: 0022544
Shop #: WSC 01236
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
The brake code sounds bad?
Old Jun 12, 2008 | 01:30 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Probably not a problem...
Could be old codes that were never cleared.
You'll get #1 whenever you disconnect the battery.
#2 may or may not be a current issue. If you don't have a CEL or warning, don't worry about it..
Old Jun 12, 2008 | 01:56 PM
mastrpdawg's Avatar
Default Thanks again Steve!
I actually pulled the battery cable yesterday...the APR program was going nuts alternately blinking my check engine light and the EPC light after I tried locking it right before I took it to the dealer for the 45K service. It wasn't the normal 3 second duration to signify the lock was enabled - it was going on forever. Called APR and they told me to reboot the car and everything normalized.
No CEL for the the second issue either.
The car should have come with the remote windows and one touch unlock already ;-)
Thanks for the info!!!
C Tang
A6 (C7 Platform) Discussion
May 5, 2018 06:27 PM
ttmxp
VAG-COM Discussion
Jul 13, 2007 02:10 PM
Theresias
TT (Mk2) Discussion
Aug 17, 2006 06:47 AM
JustAdam
Aug 8, 2006 05:16 PM
chelskiSW6
Apr 20, 2005 08:10 AM
