Fault Codes/help
Old Mar 15, 2006 | 04:54 PM
tcheat's Avatar
Default Fault Codes/help
My 2001 TT has had cold start issues since I bought it 18 months ago. 2 Audi dealers have been no help. I've replaced the temp sensor with a green top and also replaced the battery. It is still running really rough when cold and I'm getting a CEL frequently. I finally bought a cable and VAG-Check for my IPAQ and here are the fault codes I'm getting:
16684 - Random Misfire Detected - Any Cylinder B 35-00
16885 - Cylinder #1 - Misfire Detected A or B / Blink 35-00
Allegedly, this Audi has had the coil pack recall. Currently I'm at 62k miles.
Any help would be appreciated.
Tim
Old Mar 15, 2006 | 04:56 PM
Kareem of Elise's Avatar
Well, coil packs aren't that expensive.....Give it a shot.
Old Mar 15, 2006 | 05:03 PM
GeTT da NeTT's Avatar
Change the plugs while your at it, they go fast in the boosted world...
Old Mar 15, 2006 | 05:19 PM
tcheat's Avatar
Default Any plug recommendations?
Thx
Old Mar 15, 2006 | 05:24 PM
blackfnTTruck's Avatar
I had the random misfire code several days ago, turned out to be coil packs.
Old Mar 15, 2006 | 05:39 PM
Well, DENSO iridium IK 22s should work.
Old Mar 15, 2006 | 05:47 PM
Those are a range colder than stock.....
Old Mar 15, 2006 | 05:49 PM
Thanks Paul, so what's stock?
 Michael S. Palmer
Old Mar 15, 2006 | 05:53 PM
Default I don't have that info handy.....
Maybe someone with better knowledge can answer. I'm not sure how a stock TT would run with those. I've got them on, but I'm fairly modded.
Old Mar 15, 2006 | 06:35 PM
tcheat's Avatar
Default Thanks
New coilpacks on order.
FWIW, the VAG-Check is a pretty handy tool.
Tim
