flashing CEL... please help.
Old Jan 28, 2005 | 06:05 PM
andrew.tt's Avatar
Default flashing CEL... please help.
...under WOT the car hesitates and stutters. this has been happening all week with sustained temps below freezing. This morning it threw a bank 1 catalyst code (which is odd because I changed the pre-cat o2 sensor 10k miles ago)
On the way home tonight I got a flashing CEL under WOT ... I let off the gas and the CEL eventually stopped and went out.
VAG reveals this...
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
any ideas?
Old Jan 28, 2005 | 06:27 PM
kodeTT's Avatar
Elder Member
Default possible coilpacks? check your plugs to see if anything is visible...
like rich or lean condition on the plugs. but it sounds like a coilpack issue.
Old Jan 28, 2005 | 06:34 PM
TTinCT's Avatar
Rest In Peace
Default I got a flashing CEL when >>>
i was driving back from PA in the mother of all rain storms...i think i built up some condensation after idle...car stumbled hard..CEL flashed then cleared. Misfire error as well...
New MAF went in and all was well.
Do you leave your car indoors in a warm environment?
Old Jan 28, 2005 | 06:42 PM
andrew.tt's Avatar
Default car is garaged, but not warm.
it's been doing this hesitation all week. only tonight has it thrown codes... and this is the 1st CEL i've seen in a long time. and i've never seen one flash before!
only happens under wot.
andrew.tt's Avatar
are the cyclinders left to right ... 1-4?
Old Jan 28, 2005 | 06:50 PM
TTinCT's Avatar
Rest In Peace
Default I like bills suggestion of checking your plugs>>>
see what kinda shape they are in...then coilpacks....
i was thinking if you had a condensation problem in some way it would have been similar to my experience....
Old Jan 28, 2005 | 07:23 PM
GorTT's Avatar
Default I ALWAYS get cel's at the beginning of winter - cold, damp >
condensation. Seems everyone here does, but never a flashing. Yours sounds like coilpack - thats the ONLY time I ever got one, and there was a recall on them, fyi.
Old Jan 29, 2005 | 04:09 AM
petervan's Avatar
Member
VAGcodes should tell..probably not due to cold..tempermental cars..big bore USA next
Old Jan 29, 2005 | 05:37 AM
andrew.tt's Avatar
Default thanks guys. one more thing >>
do you tthink it's odd that I had felt the harsh stutter all week but only got the CEL and the dtcs last night? do you think there is a threshold for tripping off these things?
Old Jan 29, 2005 | 05:41 AM
GorTT's Avatar
Default in my case, yes. I'll get the stutter, sometimes cel, sometimes not >
I'd go for a combination of condensation/moisture and now just maybe c-p; have you tied it to a fillup, or to an empty tank, btw?
