G200 Zero Help with VCDS
Old Jun 27, 2014 | 03:56 PM
eatumup's Avatar
Default G200 Zero Help with VCDS
I have an 01 TT 225 that I am trying to zero the lateral sensor on. I found a post https://www.audiworld.com/forums/sho....php?t=2746174 where rrgerman provides instructions. Unfortunately the actual step that should reset the sensor I am unable to preform. So I am looking for some help.
I am using the Ross-Tech Key USB software. Here are the steps from that post. (step 15) I do not have a on/off/next button to click.
  1. [Select]
  2. [03 - Brake Electronics]
  3. [Measuring Blocks - 08]
  4. Group 004
  5. [Go!]
  6. Check field 2, the value has to be between -1.5 and +1.5 m/s².
  7. [Done, Go Back]
  8. [Coding-II - 11]
  9. Enter 40168, to enable the basic setting.
  10. [Do it!]
  11. [Basic Settings - 04]
  12. Group 063
  13. [Go!]
  14. Activate the Basic Setting.
  15. [ON/OFF/Next]
  16. After a successful basic setting, field 2 should say "OK".
  17. [Done, Go Back]
  18. To make sure the basic setting was succesful, check the sensor again.
  19. [Measuring Blocks - 08]
  20. Group 004
  21. [Go!]
  22. Check field 2, the value has to be between -1.5 and +1.5 m/s².
  23. [Done, Go Back]
  24. [Close Controller, Go Back - 06]
Are these steps not for my software?
OSTTalex
Mar 5, 2011 10:06 AM
Monkeyboy
VAG-COM Discussion
Oct 21, 2008 05:37 AM
Always Overcharged
Dec 14, 2005 08:48 AM
jprice@CPS
Apr 22, 2005 04:48 PM
S4zero8
Feb 19, 2004 05:04 PM
