Glove box stuck closed. I looked for a definitive fix in "search" but have found none...
Old Jul 4, 2007 | 02:38 PM
ZGTT's Avatar
Default Glove box stuck closed. I looked for a definitive fix in "search" but have found none...
anyone have details on a way to open said door?
TIA!
Old Jul 4, 2007 | 03:45 PM
MaxHedrm's Avatar
Default Pop the side panels off ...
the cover & piece underneath ... where the fuses are on the driver's side. Then you can actuate the passenger's side pin when you pull the handle to release the driver's side.
Old Jul 4, 2007 | 04:20 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Sooo...How many burittos will it hold?.......>
LOL...Yup, pop the side panel, push the pin.
Good luck Bob!
Old Jul 4, 2007 | 04:53 PM
ZGTT's Avatar
Default I have been looking around under that cover... no obvious place
to accuate the latch.
Old Jul 4, 2007 | 04:54 PM
ZGTT's Avatar
Default WHAT BURITTOS!
and more importantlly... what pin! lol
Old Jul 4, 2007 | 04:55 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default The pin is on the same plane as the handle...>>
bout 1/4 inch across....Look for a hole with the pin in it under the right side pop-off panel. Push while pulling the handle
Old Jul 4, 2007 | 06:22 PM
ZGTT's Avatar
Default himm.. the only hole that matches that description has a flat cast aluminum piece in it
that seems to not want to move in any direction.
Old Jul 4, 2007 | 06:33 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Are you sure you're looking in the right place?
Old Jul 4, 2007 | 07:04 PM
MaxHedrm's Avatar
There are 2 covers, the one that pops out by hand & the one you have to remove screws for.
Old Jul 4, 2007 | 07:33 PM
ZGTT's Avatar
so I am to assume it is under the second cover? ;-)
