Headlight problem
Old Feb 18, 2005 | 08:29 AM
TTQuattro's Avatar
New Member
Default Headlight problem
My right side main headlight bulb will not turn on. It used to do that before, but would come on if you tapped the lens. Now, it won't. The bulb was replaced, and it made no difference. I am trying to remove the bulb, but when I pull, it seems to want to pull the spade connector with it, instead of just coming out.
What should I attempt next?
Old Feb 18, 2005 | 09:46 AM
YosemyTT's Avatar
Default I have no clue. Sorry.
It sounds like you have a bad connection somewhere. Have you checked as many of the wires you can see as possible?
Old Feb 18, 2005 | 10:18 AM
JustJeff's Avatar
Default try the main headlight connector.
on the left here.
<img src="http://uh.clem.home.comcast.net/images/rear2.jpg"><ul><li><a href="https://forums.audiworld.com/tt/msgs/1194378.phtml">Headlight connector</a></li></ul>
Old Feb 18, 2005 | 10:20 AM
JustJeff's Avatar
Default Which bulb are you trying to access? the main Xenon has no metal clip...
This is the black cover you need to remove.
As you can see, there is not a lot of room.
<img src="http://uh.clem.home.comcast.net/images/cover1.jpg">
<img src="http://uh.clem.home.comcast.net/images/passenger.jpg">
Remove the spring clip, remove the cover.
<img src="http://uh.clem.home.comcast.net/images/clip.jpg">
Twist the Black/Red **** CCW.
<img src="http://uh.clem.home.comcast.net/images/twistredCCW.jpg">
Twist the ring CCW. Note the position of the tabs.
<img src="http://uh.clem.home.comcast.net/images/knoboff.jpg">
<img src="http://uh.clem.home.comcast.net/images/twistknobCCW.jpg">
The bulb will then be loose. Also note the tabs on the bulb. It just sits in the ring.
<img src="http://uh.clem.home.comcast.net/images/bulb.jpg">
This is gonna be tough to do not seeing the actual parts. It's gonna be tough to align all the tabs if you really can't see them all.
good luck
Old Feb 18, 2005 | 10:37 AM
TTQuattro's Avatar
New Member
Default Mine aren't Xenon and the actual bulb is just held onto a spade connector
then goes into the assembly. The spade connector seems to want to come off with the bulb...
Old Feb 18, 2005 | 12:40 PM
JustJeff's Avatar
then this should detach in a similar way as the fog light bulb
Old Feb 18, 2005 | 12:48 PM
TTQuattro's Avatar
New Member
just pulling it?
Old Feb 18, 2005 | 02:14 PM
JustJeff's Avatar
Yes, but it may be on there hard.
 Michael S. Palmer
Old Feb 18, 2005 | 04:01 PM
TTQuattro's Avatar
New Member
I feel like I'm gonna break it.
mkongsiri
May 27, 2014 06:29 AM
theaero
Aug 7, 2010 07:34 PM
easman61
Sep 3, 2006 12:23 PM
ThermalX
Apr 13, 2005 09:54 AM
