Help
At that point it is a $600 dealer installed option. Better going aftermarket.
The one touch windows are standard. If they are not working have the service department fix them for you. Both windows are one touch up and down. You should also check to make sure the window pinch feature is working. Do this by getting a roll of paper towels and open the window then close the window on the paper towels. The window should reverse direction and then stop. Check both windows.
Make sure you have the first aid kit in the passenger rear arm rest compartment, the cd changer would go in the drivers rear arm rest.
Make sure you have all of the tools that should be in the car, also check for the safety triangle.
By the way, congrats on getting a great car
What color? where do you live?
Close the window completely by lifting the power window switch and holding.
Release the switch and then lift it again for a second.
The convenience feature is now activated.
Worked for me:
The CD changer was a premium not standard feature.
The Xenons and 17" wheels were a premium package. Standard version has 16" wheels and no Xenon.
Enjoy your TT....
