HELP.......
May want to check the connections if you have not already.
BTW, do you have the imobilizer?<ul><li><a href="https://forums.audiworld.com/tt/msgs/242728.phtml">https://forums.audiworld.com/tt/msgs/242728.phtml</a</li></ul>
Well, if when you turn the key to accessory, and then to on you will see a key symbol in addition to the airbag, ABS, battery info.
The immobilizer prevents the car from being stolen, and has been recentely added to newer TTs.
I do believe PES has a solution to this, I'd give Tony a call first thing in the morning.
