Help,
Old Mar 3, 2009 | 05:52 AM
A8inLubbock's Avatar
Default Help,
My partner has an 02 TT Roadster, the buttons on the lower console will not activate the trunk or gas flap, and she is out of fuel. Is that a fuse, or gremlin, owners manual does not address manual release of gas flap. Her key will activate the trunk, so it makes me think it could be a fuse, but the Owners manual does not address that either. Any ideas? TIA
Old Mar 3, 2009 | 05:56 AM
JustJeff's Avatar
Default behind the passenger seat, in the cubby, is a handle to open the trunk. In the trunk, open the flap
by the tail light, there is a cable with a rubber sleeve on it (my have a yellow tag on it), pull it, the gas cap will open.
Old Mar 3, 2009 | 05:57 AM
InTTruder's Avatar
AudiWorld Awesome User
Default Gas cap manual release under the flap on the right side of the boot.
As to the universal failure of the switches, that seems odd. From work I can't offer help.
TTinCT's Avatar
Rest In Peace
Default check the fuse block under the battery cover>>>
corrosion there causes numerous issues....
Old Mar 3, 2009 | 05:59 AM
JustJeff's Avatar
that's not the issue at all, this is a known software problem. It fixes itself in most cases.
Old Mar 3, 2009 | 06:06 AM
Default Re: Help,
Hello from Texas, thanks for all of your info, I'm going over there and check all of your ideas.
Old Mar 3, 2009 | 06:11 AM
TTinCT's Avatar
Rest In Peace
Default yeah, i forgot...you are the SME in all things TT>>>
tell me how checking there for corrosion is a bad thing...
Old Mar 3, 2009 | 06:55 AM
TTinCT's Avatar
Rest In Peace
Default Jeff...sorry about the SME comment>>>
having a bit of a bad day...and you have always provided great info to the forum...
That said, knowing how cranky the TT is with electrical, there have been issues related to the fuse block, green temp sensor...etc...still thinking checking that fuse block is not a bad idea, and should not be dismissed as "not the issue at all" when it could be remotely possible
Again, apologies for the comment...
Cheers..
Hans
Old Mar 3, 2009 | 08:21 AM
blackfnTTruck's Avatar
Default I've had the same thing happen several times, gremlins, after a couple of starts....
all was working OK again. Same thing with the radio, sometimes it comes on by itself, sometimes no volume, after restart all was OK.
Old Mar 3, 2009 | 06:20 PM
Default Re: behind the passenger seat, in the cubby, is a handle to open the trunk. In the trunk, open the f
Final episode, after 4-5 evolutions, both buttons on the lower console, started working again. I love a car that heals itself. Thanks to all that helped us out.
Ptldm3
TT (Mk2) Discussion
Dec 11, 2017 01:30 PM
achTTung-TT
16
Jan 10, 2006 04:54 PM
ooyahhh
Oct 9, 2003 07:01 PM
TT in TX guy
Jun 9, 2003 02:54 PM
flyboynj
Oct 20, 2001 06:05 PM
