HELP!......Again
Old Jun 16, 2006 | 06:47 AM
andye12345's Avatar
Default HELP!......Again
Brought my 2002 225R into dealer for check engine light and erratic fuel gauge. They told me that a speed sensor would cure both problems. Not a half hour after I picked up the car the light was back on. I brought it back and they told me that I now need an instrument cluster. I had previously sent the cluster to BBA for the erratic fuel problem and they told me nothing was wrong with the cluster. The car pulls a code 501 from a standard OBDII reader. What can I do?
Old Jun 16, 2006 | 06:51 AM
PracTTical's Avatar
punch the stealer!
Old Jun 16, 2006 | 06:52 AM
kodeTT's Avatar
Elder Member
Default could be the fuel sender and relay.
search the archives...and find another dealer or tuner.
Old Jun 16, 2006 | 06:54 AM
TTinCT's Avatar
Rest In Peace
Default if the car is CPO'd>>>
let them replace the cluster...and whatever else needs to be done. If not, take it to reputable mechanic, as that is why they call the dealer, the "stealership"!
Old Jun 16, 2006 | 07:00 AM
Greg225TT's Avatar
Junior Member
Default I would second that the Fuel Sending units might have gone bad....
that was the symptom when mine went bad. My fuel gauge was very erratic. I would fill up and right after it showed that I only had between 1/2 or 3/4 of a tank. Not sure what code mine was pulling at the time since I did not have my VAG-COM then.
djgonzo007
10
May 31, 2006 10:59 PM
BIGDROCH
11
Sep 12, 2004 07:04 AM
wOOgiTT
13
Jan 21, 2004 12:51 PM
Mike Tucker
Aug 18, 2002 09:00 PM
