Help, with post Limp and Boost issues
Car is a 2000 180Q
Got a coolant flush last week and after hitting 15psi a few times, I hit limp mode (5psi) and I got a check engine light and a code of 17544 - Fuel Trim: Bank 1 (Add): System too Lean P1136. I heard a hissing sound and found the cracked vacuum hose. I replaced the hose, cleared all the codes with VAG, turned the boost machine off, took out the ****/3bar, and I can only hit 7psi on APR 91 software. I tried disconnecting the battery for a few hours with no help either.
The forge DV sounded ok too at 7psi, with the regular swoosh between shifts.
Can anyone help, THANKS!
I replaced both o2 sensors 5000miles ago too. MAF isn't that old either, 10K ago??? Coil packs and plugs were done 10K agoo too.
It's weird, I was getting 15psi with a cracked hose and now I'm getting 7psi with a fixed hose.
