here is a boost question...
If it has been hot lately, you may need to dial back the boost machine a bit....IMO
If you have no noises from the DV you're probably OK, but they rarely hold up this long to high boost conditions. I'd think about an upgrade there too!
holds at 0-5
2nd gear- spikes between 14-19 holds at 10-12
3rd gear- spikes between 15-20 holds for a second at 15 then drops down to 10 and keeps falling untill i shift into 4th
4th gear- spikes between 15-20 holds at 12-14
And my boost machine was dialed in at 4 turns for boost and 3 or 2 turns for onset.
with these numbers does it still point to a faulty MAF or DV?
Start there
Otherwise your boost sucks! WAY too much is bleeding off. More than we normally see with just a bad MAF...
