Idling problem
Old Dec 25, 2014 | 12:22 PM
dburkh91's Avatar
Default Idling problem
I have a 2001 TT225. It has a slow drain on the battery which will kill it if I let it sit for two or so weeks(don't drive the car much recently). Anyways, after i jump start it, it will idle fine for about two minutes. All at once the rpms drop, the tach bottoms out, battery light flickers, then it picks up and is on its way. It does it fairly consistently for about ten minutes. Also whenever it does this, i can hear a whirring noise coming from the alternator. Does anyone have any ideas, or had this happen to you?
Old Dec 26, 2014 | 07:47 AM
Vegas-roadsTTer's Avatar
Default WAG
Wild Assed Guess. Never heard of this problem before but my guess is that you have a battery short. The dropping RPM and alternator noise are due to a very heavy alternator load, like a serious short. My guess is that shorts in the battery are being burned away when you start the car after a long period of non-use.
Old Dec 29, 2014 | 04:26 AM
dburkh91's Avatar
Thanks for the reply, I'll have to see if a new battery will take care of it. I appreciate the input!
Old Dec 29, 2014 | 07:28 AM
Default Check battery voltage first
If there are significant battery shorts, your car should crank slower than normal after not being used for a day or so and the battery voltage before starting will be under 12.6V. It would also be useful to check the voltage after starting and during the rpm changes to see what the alternator is doing.
ramazan topal
Q7 MK 1 Discussion
Dec 17, 2018 09:58 PM
Jadelyoness
Aug 19, 2017 08:00 AM
4Bidden
Canadian Discussion
17
May 9, 2007 10:09 AM
ak_random
Oct 12, 2006 03:32 PM
sanjay2.7T
Sep 11, 2006 06:31 PM
