ignition problem, please help >>
Here's the story. I installed an optima red top less than a year ago and it was not holding a charge overnight. If I got it started in the morning, and went about my business it would stop and start all day. But, when left for long periods the battery would die. So I ruled out the alternator and bought a die-hard battery from sears.
<img src="http://s7.sears.com/is/image/Sears/02833347000?layer=comp&wid=190&hei=190&fmt=jpeg&ql t=75,0&op_sharpen=0&resMode=norm&op_usm=0.5,1.0,0. 0,0">
This has fixed my problems for the time being, but I've been monitoring the battery with a voltmeter at the end and beginning of the day. After running the battery during the day I take a voltage of 12.90V. In the morning after it sits all night, I get 12.60V.
Question 1) is this normal or do I have a drain somewhere?
Question 2) if I have a drain, how can I determine where it's coming from?
Question 3 is possibly starter related. Simultaneously I get a horrible screech from the drivers side engine bay on every start. It used to be only the first start of the morning, now it's every start. A friend stuck his head under the hood on start and pointed at the starter as the origin of the sound.
<img src="http://img.autopartswarehouse.com/live/F500084482BOS.JPG">
In my not-at-all-expert opinion I think two things. A) it's the starter (heh). B) it's the ignition switch hanging on to the start for too long. I almost want to rule that one out since I replaced the ignition switch a short while ago because it went completely south. Lastly, anyone know the part number for a 2000 tt fwd (engine code atc) starter?
ok collective minds... go!
thanks
Andrew
100% charge= 12.65V
50% Charge= 12.20V
25% Charge= 11.95V
Dead= 11.60V
When the car is running (with a good battery fully charged the Alt. output to the battery will be about 13.6V. If the battery is discharged or in the morning at first start look for 14.1. With a heavy load (lights), running voltage will be 13.1. There will always be a light load on the battery when the car is off (ECU, Radio, clock, alarm, etc.) but this will be minimal. A good way to check battery health is to undo the terminals, let sit overnight, then voltage check in the morning. Use the voltages above to determine health
Hope that helps!
