Longitudinal Acceleration Sensor
Old May 23, 2010 | 04:28 PM
TPW's Avatar
TPW
Default Longitudinal Acceleration Sensor
My 2001 225HP TT has always had the ABS and the ESP indicator light on. My Vag Com says Longitudinal Acceleration Sensor Fault. So I replaced both the long and the lat sensors today with some used ones, and still got the same code. Could something else need replacing, or should I try another set of sensors?
Old May 24, 2010 | 05:01 AM
TTnLA's Avatar
did you try clearing the code?
Old May 24, 2010 | 06:48 AM
TPW's Avatar
TPW
Yes, many times. Should the car be moving?
Old May 25, 2010 | 08:04 AM
HaTTfield's Avatar
When you clear the code, does it come back immediately, or after you have been driving? Is there only one code or multiple?
When my longitudinal sensor went (the one under the steering wheel, I think that's the long one...), I only had an ESP light, no ABS, and it just cleared and stayed clear.
Old May 25, 2010 | 10:40 AM
TPW's Avatar
TPW
I think I may have found the problem, after searching the the archives and the FAQ, I found that there are two sensors with the same number. So I will be replacing the one behind the glove box next.
Old May 26, 2010 | 05:31 PM
J. Patterson's Avatar
It is not unusual to have to change both of them. It seems that the DTC can be less than trustworthy as to which one is bad. I had to change them both a couple years back too.
Old Jul 9, 2010 | 07:54 AM
F/-\ST_TT's Avatar
How much did both of the acceleration sensor and it is worth it? I don't really feel much of a difference is handled when the ESP come on.
chTTi
11
Apr 17, 2019 08:06 AM
snowchaser
Mar 30, 2012 09:34 AM
SFexBOY
Oct 18, 2007 08:29 PM
TTagz
12
Aug 11, 2005 06:04 AM
TTurntable
Jun 27, 2004 06:55 PM
