Multiple Codes
Old Mar 5, 2009 | 06:57 AM
hOz's Avatar
hOz
Default Multiple Codes
I finally finished the winter maintenance marathon and I'm trying to track down the last couple of codes.
I've got 01324 (abs) 01312, 01314, 01316. All indications is that there is some sort of communication issue on the bus. Abs AND the haldex failing at the same time isn't likely in my book.
The initial symptoms were air bag and esp lights. I had originally thought that the problem was the longitudinal sensor and replaced that. I couldn't (and still can't) find the plug for my palm so I can plug in to vag it. The codes were given to me by my mechanic yesterday (he replaced a pair of torn cv boots for me).
Maintenance included PCV rebuild. All fluids, heatshield, maf cleaning, silicone hose replacement, new bushings on sway bars and lateral sensor replacement. The lights have been on for some time so I doubt it's anything that I triggered by all this.
Any ideas on where to start looking? I'm going to go and look at the fuses but I have no idea where to go from there if they're all good.
95k miles.
Old Mar 5, 2009 | 07:10 AM
TTinCT's Avatar
Rest In Peace
Default there are two sensors on ESP cars>>>>
one under the steering column and one next to the glove box...
Haldex errors would be related to ABS failure as they are tied together...
You will need to check the wheel sensors too...looks for wire breaks and such...
Old Mar 5, 2009 | 07:13 AM
hOz's Avatar
hOz
Default Replaced glove box one.
I don't think it's the other sensor as there are no sensor codes being thrown. Not sure if there ever were. From earlier posts I assumed that the sensor was the reason the lights were coming on.
My cluster is starting to go too, btw. Display is missing half the lines now.
Vanhickey
Jul 17, 2018 08:16 AM
TheHersh
Aug 1, 2011 10:22 PM
TTagz
17
Jun 21, 2010 12:30 PM
dieselfitter! 251
Nov 18, 2008 06:15 AM
