Need alignment advice...
Old May 29, 2005 | 10:45 AM
RS4JAG's Avatar
New Member
Default Need alignment advice...
<center><img src="http://pictureposter.audiworld.com/10402/tt_alignment.jpg"></center><p>Would someone be willing to look at these specs from my dealer's alignment? I just had them install 18x8.5" wheels &amp; ps2's, ground control front camber/caster plates, eibachs &amp; bilsteins w/ a full kmac combo, and want to ensure I have a good set-up. They still need to finish up a few things on Tuesday, so if I need them to make some refinements, I still have time, based upon your input. Also, is it correct that I should expect to adjust the alignment in 500-800 miles? Thanks in advance. I have so much for which to thank this forum...hopefully, in a few weeks I'll be able to unveil my highly modified '05 225 coupe! It has been very hard to keep it under wraps these past several months, but I think you'll like it. Thanks, again!
Old May 29, 2005 | 11:10 AM
Damwatsyoname's Avatar
Default i would tell t hem that those upper plates are adjustable >>>
and show them how to adjust it but the caster alighment doesnt cause wear problekms due to a good cross caster alignment
Old May 29, 2005 | 12:35 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Not bad but....>>
I have the GC plates too and went with a -.9 setting which is a little more aggressive. Caster is adjustable BTW by rotating the plates, but I wouldn't worry too much about that.
you need some camber adjusters on the rear though.
-1.5 to -1.6 is a more optimal setting for a moderately aggressive street set-up. You're a little high at -2. Car will feel more nimble at a lower setting..
Old May 29, 2005 | 01:30 PM
bubba j's Avatar
AudiWorld Expert
Hmm. My dealer says Audi caster isn't adjustable. Are TT's different?
Old May 29, 2005 | 01:40 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default It isn't, but the GC Camber plates allow it....>
<center><img src="http://images7.fotki.com/v150/photos/7/7305/1789110/DSC03233-vi.jpg"></center><p>
DCBallroad3
Rocky Mountain Discussion
10
May 9, 2008 10:38 PM
AK_TTuner
May 9, 2005 12:36 PM
power6
Jun 11, 2002 12:22 PM
