need help
Old Aug 11, 2007 | 11:19 AM
KingTT's Avatar
New Member
Default need help
i tripped a code on the vag it says evap leak: no signal. was wondering what this is. also this code is making my CEL blink when i hit boost
Old Aug 11, 2007 | 12:15 PM
KingTT's Avatar
New Member
here is the code 17883 - EVAP Leak Detection Pump: No Signal P1475 - 35-10 - - - Intermittent
Old Aug 11, 2007 | 12:57 PM
ttmxp's Avatar
New Member
Default seems like ...
17883/P1475/005237 - EVAP Leak Detection Pump: Malfunction/No Signal
Possible Symptoms:
Malfunction Indicator Light (MIL) active
Possible Causes:
Hoses to Leak Detection Pump faulty
Wiring to Leak Detection Pump faulty
Possible Solutions:
Check Hoses (Pressure/Vacuum) to Leak Detection Pump
Check Wiring to Leak Detection Pump according to Wiring Diagram<ul><li><a href="http://wiki.ross-tech.com/index.php/17883/P1475/005237">http://wiki.ross-tech.com/index.php/17883/P1475/005237</a</li></ul>
Old Aug 11, 2007 | 01:13 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Blinking CEL is not good...>
Not supposed to drive it when blinking..
That code shows up occasionally and when cleared goes away many times. Pumps are starting to go though. They can be re-bolted together and rejuvenated pretty easily..Any other codes showing up?
Old Aug 11, 2007 | 05:10 PM
KingTT's Avatar
New Member
Default no thats the only code i cleared it and it has not come back
i think it has something to do with the fuel line is this right
Old Aug 11, 2007 | 05:15 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Coulda been...>>
something as simple as topping off your tank (don't). If it hasn't come back, don't worry about it!
Jorge Vargas
Jun 17, 2015 08:52 AM
wchp
Q5/SQ5 MKI (8R) Discussion
Dec 18, 2014 07:54 AM
Legal Brown
Nov 29, 2009 05:57 AM
slow ride
Mar 12, 2009 02:39 PM
VTstage3a4
May 25, 2003 08:16 AM
