No compression
Old Dec 19, 2015 | 05:21 PM
DarinB's Avatar
Default No compression
Have 2001 Audi TT I currently have no compression my car turns over but won't start. Belt and gears look fine and they're aligned. I have no idea what to do next.
Old Dec 20, 2015 | 07:00 PM
Mister Bally's Avatar
Did it used to work and suddenly not start? You didn't replace the timing belt after it snapped or anything like that? Hard to believe no compression (meaning zero in all cylinders, verified with a compression gauge) yet belts are good and aligned. The timing belt is rotating and so are the camshafts? You need to verify this. I'm Asking in case the woodruff key on the camshaft sprocket snapped and the camshafts are not rotating while all of the exhaust valves got bent from pistons hitting them. Things would look aligned while the valve train got "grenaded"
Basically, standard automotive troubleshooting techniques apply here.
ollaaay
Audi 100 / A6 (C4 Platform)
Oct 21, 2017 11:12 AM
selfproclaimedv8buff
22
Jun 27, 2002 08:39 PM
Rich L.
Jan 17, 2001 07:04 PM
Ron
Feb 18, 2000 07:43 AM
