o2 sensor replace >>
Old Jul 19, 2004 | 08:39 AM
andrew.tt's Avatar
Default o2 sensor replace >>
Saturday before cruising to waterfest I replaced my pre-cat o2 sensor. Just precautionary because I recently replaced my MAF (believe it or not, for the 1st time) at 85k and I figured this is next in line.
the price of the actual sensor through the dealer is around $200 not including labor (p/n 06A906262AG)... the price of the vw plug?... $20 (p/n 06A906262Q). the only difference is a longer wire going from the sensor to the connector which I wound up tucking into the connector cover.
<img src="http://www.squarewave.us/army/andrew/ttStuff/IMG_2169.jpg">
a little WD40, o2 socket and a breaker bar (7/8" came in handy... though you can use an open end wrench) and the thing came right out. It comes with anti-seize on the threads so I just torqued the new one in (55Nm I believe). I have a FWD 180 (or whatever at this point) and the cat is in a more accessible area than on the 225.. so do some research before you jump right in.
<img src="http://www.squarewave.us/army/andrew/ttStuff/IMG_2168.jpg">
looks like someone's been roasting marshmallows with it.
<img src="http://www.squarewave.us/army/andrew/ttStuff/IMG_2170.jpg">
Thanks to Dave for his helping hand and for getting me the o2 socket. The longest part of the install was jacking the car....
I got most of my info from fredrommy's post... see link below &gt;&gt;<ul><li><a href="https://forums.audiworld.com/tt/msgs/1086859.phtml">https://forums.audiworld.com/tt/msgs/1086859.phtml</a</li></ul>
Old Jul 19, 2004 | 08:42 AM
Pearly's Avatar
Junior Member
Any idea if the VW plug will work on the 225?
Old Jul 19, 2004 | 08:47 AM
JustJeff's Avatar
wow, you got that out with just a wrench? most times they need to be heated well first
Old Jul 19, 2004 | 08:57 AM
andrew.tt's Avatar
Default yeah... I just let the WD40 soak in there for like 10 minutes.
I got lucky.... oh also.. when I did the stage III... I had a custom dp and race cat installed... so they must have had to pull the O2 sensors recently... the installers must have had to heat them.
Old Jul 19, 2004 | 09:01 AM
andrew.tt's Avatar
I think steve has written about it... although you might want to do a search on it.
Old Jul 19, 2004 | 09:11 AM
john s's Avatar
Member
I used a 7/8" box wrench, came right out, no problems, no WD40. (4 years, 71K miles)
Old Jul 19, 2004 | 09:15 AM
fredfromny's Avatar
Default Wait until you replace the back one- its a bitch!
There's a special tool that you can get though.
Old Jul 19, 2004 | 09:21 AM
andrew.tt's Avatar
Default how did you know you needed to? was it throwing DTC's?
what part # is the post-cat o2?... same as the pre-cat VW one?
 Michael S. Palmer
Old Jul 19, 2004 | 09:59 AM
fredfromny's Avatar
Default It threw a CEL and VAG tool stated O2 sensor bank 2 intermittent signal
and also 02 sensor bank 2 no signal. After clearing DTC CEL came on next day.
Old Jul 19, 2004 | 10:11 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I've got a few in the mail as we speak.....>>
VW parts lost the order, but have found it and they are on their way to me $19.46 each w/ 4 pin plug. I'll let everyone know!
