OBD code P1128
- Exhaust system components removing and installing
- Fuel injectors checking
- Fuel pressure regulator and residual pressure checking
- Fuel pump checking
- Intake system for leaks (unmetered air) checking
- Check vacuum lines for proper seal
- Secondary Air Injection (AIR) system components removing and installing
Has anyone had a similar experience with this code? Is there one particular item on the list that is a more common failure than others? Any serious advice would be greatly appreciated.
The car's performance seems to be unaffected by the CEL.
