Odd problem with boost.
Old Jul 23, 2007 | 09:39 AM
  #11
HugeTTs's Avatar
Default We are like.... TT brothers.
haha
Old Jul 23, 2007 | 10:34 AM
  #12
Blindranger's Avatar
Default Mines doing something simular...
i only notice it when the engine is cold and only when accelerating very moderately. its very minor, with quick pulses in the power, as soon as i open up the throttle it goes away. i don't even think that anyone riding shotgun would notice it unless i pointed it out. I am still finishing up the 80k service and to be honest i was hoping that it will go away with new spark plugs.
Old Jul 23, 2007 | 12:37 PM
  #13
BTTI's Avatar
Senior Member
Default Yeah! In that case...I have just one question for you...
Can I borrow some money?
Old Jul 23, 2007 | 12:42 PM
  #14
Russ Scott's Avatar
Default A new N75 helped mine, but boost leaks were the real culprit
a total of three in the tubing under the intake manifold. The black rubber hoses that attach to the nipples under the intake, and to the PCV valve, crack over time. The hoses are there to distribute vacuum to various systems, but they're also subject to 100% of the boost. They'll leak under boost pressure, setting up the surging condition you described.
If you've had the intake manifold off, retorque it too, a couple of times. New gaskets compress and the fasteners are then loose. Another solid vacuum/boost leak.
None of this presented codes of any kind on my car, just the driveability problem you described... Pressure testing with soapy water found one of the leaks. Repeated testing never revealed the other two. You have to take it apart and look it over very carefully. Replace any hose/connector/check valve that looks suspicious, has visable cracks/splits, or leaks under testing.
Good Luck!!
Old Jul 23, 2007 | 12:45 PM
  #15
SpoiledHeeb's Avatar
Except... Bryan was HATCHED!
Old Jul 23, 2007 | 01:20 PM
  #16
BTTI's Avatar
Senior Member
Default You need to HATCH some new jokes!
btw - site look good! I just registered but it wouldn't accept what I put in for meals. Damn clown...
Old Jul 23, 2007 | 01:28 PM
  #17
BTTI's Avatar
Senior Member
Default I'll keep an eye on it and maybe get it Vag'd soon >>
And as the time gets closer we'll figure out a plan for certain for TTE!
Old Jul 23, 2007 | 01:44 PM
  #18
Scenic Driver's Avatar
Default Yeah, go VAG yourself cork soaker >>>
Sounds good regarding TTE
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 23, 2007 | 02:26 PM
  #19
MaxHedrm's Avatar
Unplug it. Default mosde should be off. Might not even show up as a DTC.
Old Jul 23, 2007 | 02:28 PM
  #20
MaxHedrm's Avatar
Default Hmmm ... been considering going silicone...guess I better take a look around under there.
Since the car has 100,600 miles, It should be full of leaks by now. ;^)
