Oil Temp sender/plug concern..(ttstuff.com)
Old Apr 17, 2003 | 06:32 AM
jam75944's Avatar
Junior Member
Default Oil Temp sender/plug concern..(ttstuff.com)
I ordered a "gauge set" from TTstuff.com
The oile temp Sender and Plug did not fit my oil pan.. Does anyone know the exact size I need.. The gauges I am using are AutoMeter Competition..
Thanx all!
Old Apr 17, 2003 | 06:38 AM
JustJeff's Avatar
Default M14x1.5
Part No: 323-055
Temperature Sender: 300F/150C M14x1.5 $10.63
Directly replaces the Oil Pan Plug, and is the sensor used for the VDO Oil Temp Gauge!
Old Apr 17, 2003 | 06:42 AM
jam75944's Avatar
Junior Member
Default where do i get this from?? and will it work with the Auto Meter gauge??
thanx!
Old Apr 17, 2003 | 06:50 AM
JustJeff's Avatar
Default It's a VDO part from egauges.com, but your Autometer gauge should have come with a sender...
You got the sender that needs to go in the oil flow, like at the oil cooler line.
This is why I went with VDO, the Oil Temp sender replaces the Oil Drain plug directly.
I doubt the VDO sender will work with the Autometer Gauge.
Old Apr 17, 2003 | 06:57 AM
JustJeff's Avatar
Default What "gauge set" did you get? The one's advertised are VDO's.
<ul><li><a href="http://www.ttstuff.com/gauges_gaugepak.php">"Gauge Pak" kits</a></li></ul>
Old Apr 17, 2003 | 07:18 AM
jam75944's Avatar
Junior Member
I spoke to TTstuff and got Auto meter set, they said it would work...
Old Apr 17, 2003 | 07:21 AM
JustJeff's Avatar
Default They said "what" would work? The VDO sender, or the Autometer kit?
Did you get the 1/8NPT sender with the Autometer gauges?
If so, then this will not screw into the drain plug.
Old Apr 17, 2003 | 07:36 AM
jam75944's Avatar
Junior Member
Said the AutoMeter kit would work, with the adapter.
Old Apr 17, 2003 | 07:53 AM
JustJeff's Avatar
Ok, it will, but be aware that the Autometer gauge is NPT threads, your car is not.
Old Apr 17, 2003 | 07:57 AM
jam75944's Avatar
Junior Member
Default Re: Ok, it will, but be aware that the Autometer gauge is NPT threads, your car is not.
what does that mean? will My car leak oil?
