Paging Dr Schwing
Old May 26, 2005 | 07:32 AM
TTigg's Avatar
Senior Member
Default Paging Dr Schwing
Hey Steve,
I'll try to get a better pic (when my system is done) but I'm wodering if I can squeeze a TTDA in here and route the pipes to the front grill (upper not lower) and replace with mesh grill?
<img src="http://www.eiptuning.com/eip/images/r32/eip_r32_s1_turbo_02_300.jpg">
Thoughts?
Old May 26, 2005 | 07:36 AM
joe@vwvortex's Avatar
Default Can I be the first to say..............
before you drop the coin on a turbo system - talk to Jason at Streetwerke. 380 to the wheels on a Mustang dyno running 7 psi. :-)
Old May 26, 2005 | 07:39 AM
TTigg's Avatar
Senior Member
Default Re: Can I be the first to say..............
well I did talk to him Joe and he was hesitant if he was going to "build" the kit. Talked to Marcel and we couldn't quite make things work so I've pulled the trigger on EIPs kit
Old May 26, 2005 | 08:58 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Honestly doesn't look like you could...
Old May 26, 2005 | 09:09 AM
TTigg's Avatar
Senior Member
Default Re: Honestly doesn't look like you could...
Maybe a custom end piece (to have off center MAF connection)? I'll check once it's done but I think I could route one pipe to fender area (but kept high up) and one to grill area..
We'll see - could be good?
Old May 26, 2005 | 09:19 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Too much piping in the way......can is 8" across and long..
Old May 26, 2005 | 09:20 AM
Default Ah - say Jay Ayers EIP numbers at ND and well......
they seemed a bit low although he wasn't disappointed. My biggest concern over time with EIP is programming.
Old May 26, 2005 | 10:22 AM
MaxHedrm's Avatar
Time for the LPTTDA - low profile.
 Pouria Savadkouei
 Michael S. Palmer
Old May 26, 2005 | 11:00 AM
TTigg's Avatar
Senior Member
Default well I can take proper measurements when I see it but there may be room
if not a custom heat shield will help some.
Beemer832
NY / NJ / CT Discussion
Jul 25, 2005 03:57 PM
mrjain
Feb 11, 2005 05:41 PM
CBerten
Oct 13, 2004 02:24 PM
A4AdMan
Sep 26, 2004 02:06 PM
bbaudi382
Jan 6, 2004 11:27 PM
