Possible Bilstein strut problem??
Old Jan 31, 2007 | 04:41 PM
TToplessTTs's Avatar
Member
Default Possible Bilstein strut problem??
I opened one of my new Bilstein struts and found that it has, what I'm assuming to be, drops of red hydraulic fluid down the yellow shaft. It doesn't appear to be too recent as it is somewhat dried to the outer yellow part of the strut. I did pull up the dust cover and compressed the strut a few times to see if anything came out between the silver shaft and the yellow casing, but it didn't appear to leak at all. I don't see any other place it could leak, but I also don't know how the fluid would have gotten there otherwise... If it is indeed hydraulic fluid. Should I return the strut or just install it and watch it for a while to see if it appears to be leaking?
Old Jan 31, 2007 | 04:47 PM
JustAdam's Avatar
It was probably from testing
Old Jan 31, 2007 | 05:15 PM
Member
Thanks... I'll just watch it for the first week or so.
Old Jan 31, 2007 | 05:48 PM
lkfoster's Avatar
Default Normal
I seem to remember reading someplace that a bit of oil is normal on new Bilstein shocks/struts. As mentioned elsewhere, just keep an eye on them for continued leakage.
bobbycup
Nov 3, 2014 03:12 AM
jatwrite
RS 6 Discussion (C5)
Sep 19, 2008 09:48 PM
NY2.7T
20
Aug 9, 2005 12:27 PM
