Possible boost issue?
Old Jan 31, 2006 | 09:55 AM
AvantMnkyA4's Avatar
Member
Default Possible boost issue?
upon accelration it creeps to 7psi and holds steady. I use to peak at 10-11psi and then fall back down to 8psi. I'm a stock 180 and just relocated my boost gauge. Here is my question(s):
-could my gauge be reading incorrectly?
- or is my MAF possibly going out on me?
Thanks for the help
Old Jan 31, 2006 | 10:29 AM
Audiboy's Avatar
Default if it happened right after a relocation, it's possible you have introduced a minor leak on your
boost gauge line. Otherwise, it's best to vag it to verify
Old Jan 31, 2006 | 10:31 AM
Member
Default the relocation was just disconnecting the line and moving the vent pod from the driverside to
middle vents. I will probably vag it tonight log block 32(?) for the MAF readings
Old Jan 31, 2006 | 11:58 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Kink in the hose?
Old Jan 31, 2006 | 12:49 PM
Member
good call, better check that hose too
blacks42000
Aug 7, 2009 05:39 PM
petervan
Oct 16, 2005 07:46 AM
HACK THS
Oct 3, 2005 02:34 PM
BTTI
Sep 21, 2005 09:03 AM
tfosorcim
11
Jul 13, 2004 09:01 AM
