Problems with forge DV?
Old Apr 17, 2001 | 08:43 AM
Quattromaniac's Avatar
New Member
Default Problems with forge DV?
I have a friend with an S4 that said people have been having problems with the forge valve sticking? Anyone seen this? I had a bailey and never had a problem.
Old Apr 17, 2001 | 08:46 AM
Rennen's Avatar
Elder Member
Mine's been great...no problems whatsoever
Old Apr 17, 2001 | 08:48 AM
Larrytt's Avatar
Elder Member
Default I read about it as well . . . I asked Pete yesterday about it . . .
He said that the Forge for the S4 is a different valve than the one for the TT. The S4 valve was built with a gasket or o-ring, I forgot which he said that was at the upper limits for a modified S4 and they are blowing. Forge is rushing a corrected part to Stratmosphere for them to ship to S4 owners.
You can ask Pete about it and he will explain it better than I just did.
Old Apr 17, 2001 | 08:55 AM
Bluto's Avatar
Pete said it is the S4's o ring only
Old Apr 17, 2001 | 08:58 AM
evan's Avatar
Senior Member
Default Pete's response from Friday:
Posted by Pete @ Stratmosphere on 2001-04-13 10:59:52
In Reply to: Forge DV defect crosspost from S4 forum posted by Ulmer on 2001-04-13 10:18:47
"Best we can tell it's isolated to an o-ring size issue on the 007P... valve which is the valve used in the 2.7T application. The 006 is the valve used for the 1.8T. We haven't seen any sticking issue with that. Apparently the thickness of the o-ring is at the high tolerance measurement. Forge is manually measuring all o-rings with a digitial vernier and replacing o-rings and pistons for customers.
So, we seem to be fine with the 006. The last batch of o-rings for the 007P were just a bit out of the ideal spec. -Pete"<ul><li><a href="https://forums.audiworld.com/tt/msgs/230578.phtml">https://forums.audiworld.com/tt/msgs/230578.phtml</a</li></ul>
Old Apr 17, 2001 | 09:01 AM
MichaelTT's Avatar
Senior Member
Ditto
Old Apr 17, 2001 | 12:17 PM
SwifTT's Avatar
Junior Member
Mines perfect
VooS3
Audi A3 / S3 / RS 3
Jun 20, 2005 07:18 AM
paulpas
Mar 4, 2004 09:25 AM
chisilvertip
Oct 28, 2002 04:33 AM
Ulmer
Apr 13, 2001 10:34 AM
