Problems with Malfunction Indicator Lamp
It looks like this...but with a little lightning bolt going through the engine:
<img src="http://z.about.com/d/autorepair/1/0/H/Y/87560332.gif">
Here's what my Audi manual says:
On Board Diagnostic System
The Malfunction Indicator Lamp is part of the On Board Diagnostic System.
The lamp comes on when the ingnition is switched on and will go out after the engine is started and the idle has been stabilized. This is to assure you that the Malfunction Indicator Lamp is working properly.
If the lamp does not go out after the engine is started, or if it comes on while you're driving, there is a malfunction in the engine system.
Continue driving with reduced power and have the cause corrected right away by an authorized Audi Dealer or quality workship.
If the lamp comes on, the Electronic speed limiter can also be out of operation.
The On Board Diagnostics in your vehicle monitors the various components of your emission control system.
So what the hell do I do? Take it to Audi? I hope this is covered under warranty. Any ideas?
and have it forever...<ul><li><a href="http://www.auteltech.com/">http://www.auteltech.com/</a</li></ul>
