Prototype
Old Sep 5, 2003 | 05:30 AM
JustJeff's Avatar
Default Prototype
this is the easy part.
switch bezel will be painted flat black, not left alum.
<img src="http://jbipes.home.comcast.net/jpgs/start1.jpg">
<img src="http://jbipes.home.comcast.net/jpgs/start2.jpg">
Old Sep 5, 2003 | 05:41 AM
ebb(in memorium)'s Avatar
Default so..
insert key, turn then press button, should be a pretty easy build in theory, just intall this somewhere in between the ingition and starter connection?
Old Sep 5, 2003 | 05:48 AM
Mr. Nice Guy's Avatar
Junior Member
Is this so we can pretend we're in the Batmobile or something?
Old Sep 5, 2003 | 06:11 AM
JustJeff's Avatar
Default Right. Relatively simple connection. Once ignition is turned to on...
the starter circuit is independant.
Key switch is just a momentary switch.
A relay to engage a relay is what is needed between the push button and the stater circuit.
Old Sep 5, 2003 | 06:12 AM
JustJeff's Avatar
Default The beauty of this country is...
you can pretend to be anyone or thing you want.
Old Sep 5, 2003 | 06:32 AM
EighTT's Avatar
Eighth Member of AudiWorld. God-like, glorious and all-knowing.
25 Year Member
Default Is that for...
The ejector seat? I've had a few passengers I'd like to have ejected!
Old Sep 5, 2003 | 06:41 AM
JustJeff's Avatar
You could!
Old Sep 5, 2003 | 06:49 AM
IEEE's Avatar
New Member
Default Re: Prototype....Question
Once you install this, will you be able to take the key out of the ignition, and keep the engine on??
 Michael S. Palmer
Old Sep 5, 2003 | 07:26 AM
AxeYrCat's Avatar
Member
nope... not unless you do BIZARRE things to the wiring...
Old Sep 5, 2003 | 07:27 AM
AxeYrCat's Avatar
Member
Default i had a start button on my corrado...
i put it there when the key switch broke, and it seemed easier to wire up a button with a hot lead to the starter and to the battery. it was kinda neat, but i don't know if i'd do it on a car with a working key switch...
you just doin' it for kicks?
