IT question.
Old Sep 28, 2001 | 11:07 AM
Laguna's Avatar
Default IT question.
I set up a router in my home with 4 ports. There are 5 computers in the house (all Macs). Here's the problem. Each port has an ethernet line going to each of the computers from the router. One of these lines goes to an AirPort. Can the 5th computer share the Airport if each has a different IP? The line to the Airport remember is coming out of the router and essentially uses up one port of the router. In other words, can the Airport which is attached to the wall near my desk share the signal with the 5th computer?
Confused? Have a joint and think about it!
TIA
Old Sep 28, 2001 | 11:10 AM
RTinNYC(again)'s Avatar
Elder Member
Default Have the J anyway, and just hire somebody to deal with the tedium...
really there seems to be a glut of people who know such things...
Just my $.02... ;-)
Old Sep 28, 2001 | 11:11 AM
Rennen's Avatar
Elder Member
Must be nice having an airport at your house. Has the National Guard come in and taken it over yet?
Old Sep 28, 2001 | 11:15 AM
voughtt's Avatar
Default Re: IT question.
Yes, you can do this, whether the router is really a router, or even if it's just a hub.
Shouldn't be a problem at all.
Let me know if it works. This is similar to what we're doing in my duplex; two computers wired into a hub upstairs, the AirPort plugged into the hub, and two computers using the AirPort wirelessly.
Old Sep 28, 2001 | 11:29 AM
St3phen's Avatar
Default If the fifth Mac has an Airport card, then you can run the Airport Base Station in bridging mode, or
set up a separate subnet/route to the 5th Mac.
FYI, the following IP ranges, according to RFC1918, are available for use for free on private networks. They are unroutable on the Internet itself, however. Your NATting router will take care of this.
10.x.x.x
172.16.x.x - 172.31.x.x
192.168.x.x
Old Sep 28, 2001 | 11:40 AM
Laguna's Avatar
Default Actually the 4th and 5th Macs have AirPort Cards. One is Apple's in a PowerBook, the other is ...
a USB Linksys wireless adaptor set up for my 10 year's iMac (older model). Still work?
Old Sep 28, 2001 | 11:41 AM
Laguna's Avatar
So THAT'S who those guys are!
Old Sep 28, 2001 | 11:50 AM
voughtt's Avatar
AirPort =Lucent's Apple-branded 802.11 wireless cards
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 28, 2001 | 12:11 PM
kodeTT's Avatar
Elder Member
Default you can set up airport to serve up DHCP...and have as many as 255 computers hook up.
the IP addresses have their own setting based on airport...like 10.2.1.xxx
just like setting up a router for NAT (network address translation)...
St3phen's Avatar
Yeah; Are you bridging or routing in the Airport Base Station?
