Radio Problem
Old May 3, 2006 | 02:02 PM
cyberhero's Avatar
Default Radio Problem
Good Day,
I buyed a used Bose concert cd player.
I installed everything and it's fine but 2 things:
1 - Radio don't turn off as i turn off the car like my old radio was doing. Anything i can do to fix that?
2 - it's less important but it dosen't display like my old radio in the dash
thanks for helping me
Vincent
Audi TT 225 Roadster 2001
Old May 3, 2006 | 02:10 PM
GeTT da NeTT's Avatar
It sounds suspiciously like a wiring issue. Does the radio have a CD slot in the front?
Old May 3, 2006 | 02:12 PM
cyberhero's Avatar
Default Re: It sounds suspiciously like a wiring issue. Does the radio have a CD slot in the front?
yes, I had the radio with Casette and i buyed from this forum a used cd player unit. It only turn off if i push the button, and nothing appear in my dash
Old May 3, 2006 | 02:15 PM
jman649916's Avatar
Default If your installation is as good as your grammar, there shouldn't be a problem...>>>
lol, just kidding, the first thing you should check is whether it retains memory or not...e.g. clock, bass, treble, etc...if it doesn't then you likely have the constant and switched power backwards. If it does, then you may have the constant power jumped to the wrong location somewhere in the car. Check for +12 at the switched pin, if it doesn't have +12 there, you've got a bad radio. Hope this helps.
Old May 3, 2006 | 02:16 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default OOOps....Different Bus communications system...>>
Probably won't work the way you want..
Old May 3, 2006 | 02:18 PM
Beat me by mere seconds, Rabbi. How's the painting gig going ;-)!
Old May 3, 2006 | 02:56 PM
cyberhero's Avatar
Default Re: If your installation is as good as your grammar, there shouldn't be a problem...>>>
Sorry,
No problem with memory, I will check the pin then
thanks
Old May 3, 2006 | 05:45 PM
JustJeff's Avatar
Default It can be done, but it's not easy. I haven't tackeled this one yet, maybe next....
<ul><li><a href="https://forums.audiworld.com/audio/msgs/32484.phtml">Concert II install in older TT's</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old May 4, 2006 | 04:26 AM
cyberhero's Avatar
Default Re: It can be done, but it's not easy. I haven't tackeled this one yet, maybe next....
It's really strange because it is the same connector in the back. I had a Concert I and i buyed a Concert I with CD player. All the back is the same
Old May 4, 2006 | 05:50 AM
JustJeff's Avatar
right, but it's the CAN-BUS that controlls the power and lights
