Radio Safe Mode
Old May 19, 2008 | 05:55 PM
semp's Avatar
New Member
Default Radio Safe Mode
I have a 2002 TT. The radio (Audi Concert)went into safe mode. I have no manual for the radio but I think I have the 4 digit code for it . How do I input the code?
Old May 19, 2008 | 06:02 PM
TTwizted13StrtRcr's Avatar
Member
Default STFA
...thats where i got my info at for mine
Old May 19, 2008 | 06:55 PM
David_TT225QC's Avatar
Default Press and hold RDS and the button directly above or below for a few seconds until
1000 is displayed. Use the number buttons to set the code: Button 1 corresponds to the first digit so you keep pressing it until the 1st digit is set. Dot he same with button 2 for the 2nd digit and 3 for the 3rd, etc.
When the display shows your code press and hold the RDS (and the button directly above or below it) until the radio frequency is displayed.
Done
I'm not looking at the radio which is why i can't remember the other button, I thinks it's FM or FM2, it will be obvious when you look at it.
Good luck
Old May 19, 2008 | 08:23 PM
semp's Avatar
New Member
Default Re: Press and hold RDS and the button directly above or below for a few seconds until
That did not work. The radio must be bad?
Old May 20, 2008 | 05:04 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Check the fuse on the back of the radio, and in the fuse box...Also...>
If you screw up the code input you have to let the radio sit, powered on for a number of hours before you can re-try..
Old May 20, 2008 | 07:48 AM
Which part did not work? Going into safe mode or punching in the code or....?
Old May 21, 2008 | 01:01 PM
semp's Avatar
New Member
Default Re: Which part did not work? Going into safe mode or punching in the code or....?
When I hold in the RDS & FM buttons nothing changes it still displays SAFE. I have checked the fuse in the fuse panel and it is ok.
Thanks for your help on this.
Old May 21, 2008 | 01:05 PM
semp's Avatar
New Member
Default Re: Check the fuse on the back of the radio, and in the fuse box...Also...>
Checked the fuse in the fuse box and it is ok. Not sure how to pull out the radio to check that fuse.
Thanks for your help.
Old May 21, 2008 | 01:07 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default If it's reading safe it's probably OK power wise..>
Try resetting the whole circuit by pulling the main fuse..
Old May 21, 2008 | 02:56 PM
semp's Avatar
New Member
Default Re: If it's reading safe it's probably OK power wise..>
What main fuse? And if I pull it what else will reset?
thanks again
