REPLACE ECU?
Old Jul 18, 2020 | 12:19 PM
speedgruaspanama's Avatar
Default REPLACE ECU?
I need to replace my ecu. i buy one on ebay comes with the same number part. i need to reprograming or its plug play an strat my car?
Old Jul 19, 2020 | 04:09 PM
Geomeo's Avatar
What was wrong with the old one? It’s not that easy. Look for Immo delete bosch 7.5. There is a 4 digit code that is linked to cluster and key. If you good at electronics you could swap the EPROMs over I guess.
Old Jul 22, 2020 | 05:56 AM
Breyden Phillips's Avatar
Default Depends on if there’s IMMO
I would send it off to someone and get the IMMO turned off for like $20. Depending on what car and year you have you may have IMMO on your car and it won’t work. If you do have it just send it off and get it defeated. The way to tell if you have the immobilizer is to turn your key to the on position and when all the lights light up on the dash you will see a car with a key through it. If it’s not there then you can plug the ecu straight in and you would be ok.
Old Jul 26, 2020 | 07:27 AM
Mindyk's Avatar
Default I replaced mine
If we're talking about the part also referred to as the comfort control module, it was a plug and play swap for my 2001 TT Quattro. An exact part number match is required. I had to program the keys to the module, which was easy to do.
Mine failed due to excessive moisture that got into the trunk when the convertible rear window failed. I fixed it for a while by cleaning the corrosion off the circuit board, but ultimately I had to replace it.
Good luck!
Old Jul 26, 2020 | 10:37 AM
hagakurejunkie's Avatar
Good luck!
How did you program the key fob? I replaced my CCM and have been waiting to take it someone to program my keys.
Old Jul 26, 2020 | 03:42 PM
Mindyk's Avatar
Default Key fob
There are probably lots if posts in this forum about the fob. I found an online how to guide. It was easy. This might be the video I followed. https://www.google.com/url?sa=t&sour...8cEroGoXn6BM1-
[tri]liament
Dec 24, 2003 01:46 PM
coors_can
Jul 8, 2001 06:35 PM
