rough idle when warm only
Old Jan 23, 2018 | 01:42 PM
Dbudke's Avatar
Default rough idle when warm only
01 Audi TT 225. new Maf, ox, plugs coils. Rough idle after it warms up. multi misfire lean code
Old Jan 30, 2018 | 05:04 AM
J. Patterson's Avatar
Try changing the coolant temp sensor located at the transmission end of the engine in the coolant manifold. It can send an erroneous signal to the ECU causing fuel mixture errors. Next check really well for vacuum leaks. Lots of potential for those especially under the intake manifold. Look closely at the hose from the end of the intake manifold to the fuel pressure regulator on the fuel rail. If that fails I suspect O2 sensors next. You’ll need VCDS to read the outputs on those. Good luck!
thunderbolt1
9
Aug 9, 2016 05:51 PM
Audi Junkie
Jun 5, 2007 08:20 AM
YFZ450CHUCK
Feb 28, 2007 05:39 PM
CJ Miller
Feb 2, 2006 02:10 PM
k2exoman
Jan 25, 2006 06:58 PM
