roughness on decel
Old Mar 30, 2003 | 02:48 AM
ezCrusty's Avatar
New Member
Default roughness on decel
Anyone else notice that on throttle-off deceleration from 100-90km (65-55 mph) the driveline feels rough?
Silky smooth until you decel (eg slowing for an off-ramp) then between 100 through 90 I feel somethings not right.
Curious if it's just me, or if anyone else notices it / has had it addressed.
- Thx in advance.
Old Mar 30, 2003 | 04:41 AM
jgriff's Avatar
Junior Member
Probably tires not driveline.
Old Mar 30, 2003 | 04:49 AM
undrway's Avatar
There was a technical service bulletin regarding a similar issue - YGM.
Old Mar 30, 2003 | 07:48 AM
OTOF's Avatar
Elder Member
Default Here's the TSB ... clicky linky
<ul><li><a href="http://www.springbreakdaytonabeach.com/vwtech/www.vwwebsource.com/vwtechcontent/audipdf/a300101.pdf">http://www.springbreakdaytonabeach.com/vwtech/www.vwwebsource.com/vwtechcontent/audipdf/a300101.pdf</a</li></ul>
Old Mar 30, 2003 | 08:08 AM
JaminTT's Avatar
Junior Member
not just a pretty face...8^)
Old Mar 30, 2003 | 08:09 AM
Don's Avatar
Don
New Member
Default Re: roughness on decel
If the "roughness " occurs as you decelerate through about 3000 rpm, it's probably the flywheel as described in the TSB in Denny's post. It is easiest to feel in high gear, but will be felt in all gears to a lesser degree.
Try to get them to replace the clutch along with the flywheel - that's what Sonnen in Marin, CA did for me. Others have just had the flywheel replaced and still had problems.
Old Mar 30, 2003 | 08:14 AM
OTOF's Avatar
Elder Member
(blush) I try.
Old Mar 30, 2003 | 08:59 AM
Blue TTop's Avatar
Anybody have a link for a listing of all TT TSB's?
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 30, 2003 | 09:38 AM
OTOF's Avatar
Elder Member
Default You can backtrack that link, but no....they shut down public access to the TSBs
....you'll see that the dates there stop in 2001 or so. I've posted some on the yahoo audittowners group in the "file" section in pdf format. Also, I have a subscription to them and post here when it is relevant to the TT. Haven't been any earth-shattering ones lately.
Old Mar 30, 2003 | 09:51 AM
Blue TTop's Avatar
Thanks. I backtracked on the link until prompted for a password.
