Sharing Network Printer?
Is this correct. It can't find it.
The shared printer is on Win XP. The compter try to add the shared printer is Win 95.
thanks
First things first. Can each of you ping the other? Are you both on the same network? Can you access files/network resources on each others networks?
\\24.206.xxx.xxx\share_name
That would be correct so long as that is the IP on your network. Is the user trying to print to your printer a user on your network? There are lots of things to check.
We are on different networks, but we can ping each other.
I am able to connect to them via VNC (a PC anywhere clone).
thanks
