Some electrical problems...help!
Old Mar 13, 2001 | 02:54 PM
seaTTym's Avatar
Member
Default Some electrical problems...help!
Took the TT into the dealer to get the left headlamp replaced. Headlamp had about 7-8 star-like bursts. Replaced without question by the dealer.
I noticed some problems and some odd things that I didn't notice before, hopefully you guys and gals can help.
Problems
1 - left turn signal blinks at least twice as fast as the right one which seems normal - all lamps on the outside blink at same speed as the inside arrow.
2 - front left turn signal does not blink at all.
observations
1 - A red lamp from the underbelly of the ashtray is lit. actually behind the underbelly of the ashtray. Never noticed this before. Is this normal?
2 - When high beams are on, the fog lamps go out. Is this normal?
Before I call the dealer about the problems, I'd like to also know what is up with the two odd items, so I can give them a complete punch list.
Or if any of you know of an easy solution, please post as well.
TIA
Old Mar 13, 2001 | 02:59 PM
Tron (///M)'s Avatar
Default Re: Some electrical problems...help!
observations
These are normal. Don't know about the rest.
Old Mar 13, 2001 | 03:03 PM
TTop Gun's Avatar
Member
Default Sounds like they forgot to plug the LF turn signal back in, or maybe a bad bulb...
Rapid flashing on one side is a symptom of a blown bulb.....
Old Mar 13, 2001 | 03:43 PM
TTop Gun's Avatar
Member
Default Thinking about this some more, I bet they forgot to swap the turn signal bulb(s)...
...over into the new headlight housing.....
Old Mar 14, 2001 | 03:42 AM
seaTTym's Avatar
Member
Once again, thanks for the help!
NewToAudiA42002
Aug 5, 2009 01:11 PM
Slave IV
9
Jul 31, 2007 02:39 PM
PhaZeIII
12
Aug 27, 2004 01:14 PM
bear1906
Apr 18, 2003 08:07 AM
