Spark Plug gap..
Old Dec 4, 2002 | 11:43 AM
4SFEDTT's Avatar
Junior Member
Default Spark Plug gap..
Anyone here who has changed spark plugs use a specific gap? Last night I gapped them at .32
Wondering if a closer gap might be better?
TIA
Old Dec 4, 2002 | 12:12 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Better stick with spec....>>>
According to reports over on Vortex, any variation including change of recommended plugs is taking out a relatively high percentage of the rather fragile coilpaks....
Old Dec 4, 2002 | 12:17 PM
Jim TT's Avatar
Default I don't mess with gaps on my TT at all just set them to spec, but....
Keep in mind that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
A spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximises burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
With this mind, many think the larger the gap the better. In fact, some aftermarket ignition systems boast that their systems can tolerate gaps that are extreme. Be wary of such claims. In most cases, the largest gap you can run may still be smaller than you think.
Old Dec 4, 2002 | 02:49 PM
Boosted's Avatar
Member
Default I had really good results with my Beru Silverstones, car ran smoother
had them in for about a year, until idiot at dealer through them out...
nadrealista
Feb 5, 2007 06:46 AM
nadrealista
May 22, 2006 04:21 PM
Bliggity
9
Jul 1, 2005 01:56 AM
VonK :: Retired
16
Mar 19, 2003 08:53 PM
MikTip
Misc. Models Discussion
Feb 18, 2001 01:59 AM
