Spring Compression Tool...
Old Mar 23, 2002 | 05:04 PM
CooliceTTT's Avatar
New Member
Default Spring Compression Tool...
Hey guys, what do you use to compress the springs?? I saw a while back you guys were talking about a pretty good one...
Thanks!!
Old Mar 23, 2002 | 05:35 PM
IslOMan's Avatar
Junior Member
Default Re: Spring Compression Tool...
When I did my TT, first changed the springs and later Bilsteins, I didn't need a compressor. The struts are barely compressed so I just used my impact to get the strut nut and bearing off. To re-assemble the strut with new springs I just had to (barely)lean on the nut and use the impact gun. Just my experience, yours may vary but I've got a strut compressor and didn't need it.
BTW, the "good one" compressor is a scissors type that uses a single nut adjustment that compresses the arms that hook around the springs. It's a one piece unit that won't slip off. Harbor Freight has an imported copy of this one on sale for only $29.99.
To get this price, you must select "order from catalog" and enter item number 43753-1BWA<ul><li><a href="http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=43753">spring compressor</a></li></ul>
Old Mar 23, 2002 | 06:42 PM
CooliceTTT's Avatar
New Member
Thanks!!
Old Mar 24, 2002 | 07:24 AM
smallTTs's Avatar
Member
Default Use a compressor. Please don't try without it. Check your local auto parts store...
you can buy or borrow one (deposit is returned when you return the tool).
VAP
16
Jun 21, 2007 05:00 PM
turbopunk
29
Jun 12, 2007 03:25 PM
Stonehenge
12
Jul 10, 2006 09:31 AM
Milpitas2.7T
22
Jun 8, 2003 10:10 AM
rdstter
Mar 18, 2001 01:26 AM
