Tech question:
Old Nov 14, 2002 | 08:43 AM
tsltm's Avatar
Elder Member
Default Tech question:
You know how in the morning when you first drive the car and you sit at your first light and lite white smoke comes out of your exhaust because the engine is still cold?
well I had smoke coming from the front and side of my car as well as the back which is normal. Does this mean I might have an exhaust leak somewhere?
Old Nov 14, 2002 | 08:46 AM
gtt's Avatar
gtt
Usually it's moisture as the exhaust and engine heat up.
Old Nov 14, 2002 | 08:52 AM
tsltm's Avatar
Elder Member
doubt its moisture, climate controlled garage.
Old Nov 14, 2002 | 09:00 AM
VenTTed's Avatar
I am in climate controlled garage - no white smoke here.
Old Nov 14, 2002 | 09:01 AM
gtt's Avatar
gtt
Did you stop over a manhole cover?
Old Nov 14, 2002 | 09:03 AM
tsltm's Avatar
Elder Member
nope.
Old Nov 14, 2002 | 09:09 AM
gtt's Avatar
gtt
Default Anythings possible....open hood and look for fluid stains/leaks.
and see if any fluids like oil and radiator look contaminated.
Old Nov 14, 2002 | 09:13 AM
tsltm's Avatar
Elder Member
is that in the rear???
Old Nov 14, 2002 | 09:14 AM
whodkne's Avatar
Member
You phreaks... Climate Controlled != Indoor
TTunable's Avatar
Member
Default Sure it was smoke and not steam? Maybe you ran through a puddle or something?
Does it happen all the time or just that once?
