torque steer
Old May 1, 2002 | 07:15 AM
henrytt's Avatar
New Member
Default torque steer
Does anyone get torque steer( pull to left ) when accelerating hard , either going straight or when coming out of a turn? If I start off slow and then accel fast I get a pull on the steering wheel as the turbo's start to pull. I am not happy with this and the dealer tells me this is normal. Please let me know if you have the same experience.
Thanks
henrytt
Old May 1, 2002 | 07:17 AM
JazziTT's Avatar
"Turbo's"... That must be why... you have 2!
Old May 1, 2002 | 07:21 AM
Vegas-roadsTTer's Avatar
Default Virtually none for me. Check tire pressure first.
First step is to check tire pressure to insure that both sides of the car have identical pressure. A few pounds difference could cause this effect.
Old May 1, 2002 | 07:30 AM
2953's Avatar
Senior Member
Front-wheel-drive?
Old May 1, 2002 | 07:40 AM
Larrytt's Avatar
Elder Member
Default Yes, I have torque steer in my 180TTQ, worse with the chip, but still there stock
dealer of course sees nothing wrong! lol
Old May 1, 2002 | 07:49 AM
Piker's Avatar
Default I have this too....
225QC - its fine at highway speeds or cruising, but when accelerating hard, it pulls noticably to the left as you said. I've checked the tire pressure - both the fronts are the same. I thought quattro was supposed to eliminate this effect reminiscent of my old Golf GTI. Maybe someone can drive it at Asheville and confirm that I'm not imagining it!!!
Old May 1, 2002 | 07:52 AM
4WDrifTTer's Avatar
New Member
Default I have tremendous torque steer in my 225TTQc running 235/35/19s but......
None when I was running stock rims and tires. are you running stock sizes? An APR guy told me [ at the BBQ ] that my larger rims where causing it.
Old May 1, 2002 | 08:01 AM
Piker's Avatar
stock here
 Pouria Savadkouei
 Michael S. Palmer
Old May 1, 2002 | 08:51 AM
INTT's Avatar
Default None here........
I have a 180 Quattro. I have torque steer on my front wheel drive van, but on the TT there is none. I was under the impression that Quattro sort of eliminated this problem. Never have driven a 180 front wheel drive TT, but I would think torque steer would be present. Agree that the more power you have the more this would show up on either. As mentioned, tire pressure might have some effect or possibly alignment.
Old May 1, 2002 | 10:22 AM
GoKart3's Avatar
That's what TT stands for.
njandy
A4 (B9 Platform) Discussion
19
Aug 9, 2018 02:32 PM
s_Fanous
15
Sep 5, 2017 02:17 PM
reza
Jul 11, 2006 06:35 PM
A4Rx
Apr 13, 2002 05:57 PM
kennyc
Jul 18, 2001 12:18 PM
