Vagcom help and interpretation needed:
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 AN
Component: 1.8L R4/5VT G01 0003
Coding: 06710
Shop #: WSC 08214
TRUWT28N621008619 AUZ5Z0A7230168
3 Faults Found:
16725 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
0 Faults Found:
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
0 Faults Found:
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8N1 920 980
Component: KOMBI+WEGFAHRS. M73 D02
Coding: 07244
Shop #: WSC 00000
1 Faults Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
0 Faults Found:
Address 35 -------------------------------------------------------
Controller: 8N8 962 267 A
Component: Central Lock/Alarm D06
Coding: 15980
Shop #: WSC 08602
4 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01366 - Opened Due to Crash Signal
30-00 - Open or Short to B+
Address 45 -------------------------------------------------------
Controller: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
1 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
0 Faults Found:
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 H
Component: concert II NP2 0005
Coding: 00302
Shop #: WSC 01236
1 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
End -------------------------------------------------------
I'd clear the codes and see what comes back after a couple days.
Sorry bud.. can't help ya..</a></li></ul>
