WAP from hell?
Old Dec 10, 2001 | 02:30 PM
SecuriTT's Avatar
Junior Member
Default WAP from hell?
I've got the Linksys WAP and the laptop NIC, but they won't talk. Same channel, essid, etc., the ACT light on the WAP is blinking as well as the TX/RX light on the NIC. The link light is red.
Where could I be wrong?
Old Dec 10, 2001 | 02:34 PM
whodkne's Avatar
Member
Default Maybe you have the secure communication setup...
Make sure you are using the same encrypt keys on both setups... I would reccomend no security until you get it working and then make that change.
Old Dec 10, 2001 | 02:42 PM
SecuriTT's Avatar
Junior Member
Default Re: Maybe you have the secure communication setup...
Security is set to Disable. Should I get a red or green link light on the NIC?
Old Dec 10, 2001 | 03:46 PM
whodkne's Avatar
Member
Default On the Linksys you should get a red./amber light
for connectivity and then a green intermittent light for activity. I am looking at the one in the laptop on my client's desk and that is what I am seeing.
I had some trouble setting it up... there are setting for that card not only in the software they provide but also in the properties of the card in the device manager. Check both places to make sure it is setup correctly.
Old Dec 10, 2001 | 03:54 PM
Lone Starr (Ivan)'s Avatar
Elder Member
Default Encryption types the same? This was my problem last week.
Click 128 bit, put in a word you'll remember and do that on the WAP and WPC11 then BAM!
Old Dec 10, 2001 | 06:38 PM
TTurbulenTT's Avatar
Try switching to "infrastructure" - I had same issue
Old Dec 11, 2001 | 03:12 AM
SecuriTT's Avatar
Junior Member
Where might that switch be?
Old Dec 11, 2001 | 03:35 AM
juliem's Avatar
Default What OS - winXP tries to own everything and caused me grief
till I got it to let go of security
End result is ssid, wap key and channel set only with linksys software, none of the MS dialogs. And that did it...
 Michael S. Palmer
Old Dec 11, 2001 | 08:07 AM
SecuriTT's Avatar
Junior Member
Default ME. The access point seems to be fine, the laptop just won't connect.
What lights should be on on the NIC? I get a red link light and the RX/TX flickers green.
3cat
Audi A5 / S5 / RS5 (B9)
Nov 8, 2017 05:41 PM
jimmyTT01
9
Nov 9, 2005 05:01 PM
WmChicago
Chicago Discussion
9
Oct 8, 2005 05:22 AM
SlammedA4
Nov 27, 2001 07:24 PM
