window problem
Old Mar 28, 2000 | 05:50 AM
ron n's Avatar
New Member
Default window problem
I had to order a new passenger window motor that was installed last week. It moves up and down but does not drop by the 1/4 inch on opening and close when the door shuts. They are ordering another motor. Is this the answer to the problem?
Old Mar 28, 2000 | 05:54 AM
strawtarget's Avatar
Member
Default If the window motor works when you use the control, I would suspect you have an unrelated electrical
gremlin, unless there are two window motors (one for the window up/down control and one for the automatic 1/4" door-open trick).
This is entirely my own speculation. I'm sure someone more qualified than me to answer will follow up.
Old Mar 28, 2000 | 06:06 AM
Just Plain Cliff's Avatar
Default Re: window problem
Same thing happened to me--the replacement motor failed to drop and raise the window by 1/4 inch when opening and closing the door, and also the auto-up, auto-down feature did not work properly; at first, service techs thought they had failed to program these functions; however, the cure was a second replacement window motor.
Old Mar 28, 2000 | 06:48 AM
HokieTT's Avatar
New Member
Default If you have the Comfort Pkg, check to see if the door ajar sensors work...
This is just a hunch, but one thing that could cause it is if the computer isn't realizing when the doors are closed. Another way to test this would be with the dome light, if you don't have it set to the middle position. Hope this helps.
Old Mar 28, 2000 | 07:59 AM
maddoTT's Avatar
Junior Member
My TT did this when i first got it . Do your windows go up on ONE TOUCH?,if not then try this . First put your drivers window all the way down ,then put it all the way up then let go of the switch then hold it up for 2-4 seconds this resets the windows after the battery has been disconnected . My dealer didn't even know this ,i read it in the handbook
mike1305
A6 (C7 Platform) Discussion
Jun 13, 2016 06:02 AM
TTGram
Apr 2, 2005 08:24 AM
teabagger
Oct 30, 2003 04:09 PM
TTempted
Jul 21, 2003 04:25 AM
JHB
Jun 21, 2003 02:45 AM
