Window problem, both driver and passenger side...
I don't find this to be normal.. What could be the problem? Anyone have this problem before?
When it happens, instead of using the one touch, force the window up by holding onto the window switch. This will get the window closed, and after you turn your car off and then back on, the problem should go away.
If you have this problem, beware of another one that might occur.
When I open my door, the window drops a bit to (roadster). Well sometimes it doesn't get back up, and I basically leave the car parked with the window partially opened....easy target for thieves. So just watch out for this
