window wont roll up but clunks as if trying
Old Aug 8, 2013 | 01:01 PM
soapman88's Avatar
Default window wont roll up but clunks as if trying
this is my first post so hello everyone!
I have a 2001 tt Coupe 1.8t
couple days ago i went to roll the driver side window down and as it continued to roll down i heard plastic bits breaking inside the door.
I got home pulled the door card off and noticed that white plastic clips that hold the window to the rails that it slides on were all cracked.
So to roll the window up i had to push from the bottom of the window while flicking the switch up and down, qtr inch at a time.
i have heard that it is the regulator but i just thought i would check online before throwing money i dont have at it.
any info would help! thanks alot!
Old Aug 8, 2013 | 01:34 PM
soapman88's Avatar
also i should add, that when it first broke and before i made it go all the way up it would roll up about 2 inches and stop then i would roll it down . you could do it over and over and it wouldnt go any higher.
Old Aug 8, 2013 | 05:05 PM
Prospeeder's Avatar
yes its the regulator, there just cheesy plastic wheels and little cables that wad up and break. Motors will outlive the car just about.
Old Aug 8, 2013 | 06:55 PM
soapman88's Avatar
crap.
thanks for the help!
Old Aug 8, 2013 | 07:08 PM
soapman88's Avatar
so even though it rolls down just fine you still think its the regulator?
Old Aug 9, 2013 | 05:48 AM
AudiMick's Avatar
If you own any VAG product for a period of time you will experience this.
VW/ Audi has been making these crap components for ever.
Just the plastic have broken, you can try E-bay.For a while there was a vendor for replacement plastic pieces.
Otherwise the regulators are not that expensive, about 2 hours work. You need to drill out the rivets and re-rivet the new regulator.
Old Aug 9, 2013 | 03:34 PM
soapman88's Avatar
ah ok cool thanks alot guys
bballfreak
9
Apr 14, 2019 06:59 PM
Turguin
Audi A3 / S3 / RS 3 MKII
11
Apr 14, 2017 07:39 AM
iamdrewseph
Oct 1, 2015 11:33 AM
NYCtt123
Sep 27, 2015 05:04 AM
legerrej
Sep 25, 2015 08:43 PM
