TT (Mk3) Discussion Discussion forum for the Mk3 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2014- present
Engine start system: malfunction! SOLVED
Old Dec 4, 2024 | 05:39 PM
herroimant's Avatar
Default Engine start system: malfunction! SOLVED
Walking up to my car the keyless entry and trunk buttons were not responding. Upon starting my car I was greeted with Engine Start system: malfunction Please contact service. I looked it up online and everyone said it was push to start button or the battery, I replaced the battery and $350 later still not solved. I looked under the car and saw a connector with nothing connected to it with a huge hole in my splash guard. The keyless entry antenna module was completely ripped off. When having problems with Audi it's usually not what you expect to be causing the gremlin. Replaced the Keyless entry antenna from a local VW parts department and were back with no lights on the dash.
Old May 19, 2025 | 05:51 AM
ethan0512's Avatar
I've been stuck with this error for a while with no fix i also ended up replacing battery which should have been replaced anyway. Where exactly underneath the car was this located?
Old May 19, 2025 | 05:55 AM
herroimant's Avatar
for my TT it was under the driver seat almost under the car behind
Old May 19, 2025 | 07:41 AM
ethan0512's Avatar
I have a 2017 TTS so i'm gonna look in the same area, so just to be clear under the car but almost where the driver seat is located?
Old May 19, 2025 | 06:58 PM
ethan0512's Avatar
Wow ive been dealing with this annoying problem for so long with no fix and i checked under my car after work today and could see the connector through a gash in my splash guard. module was still there but bracket had ripped off and it was unconnected, connected it again and problem solved.
leonochs122@gmail.com
Audi A3 / S3 / RS 3 MKII
Jul 10, 2024 04:30 PM
xPB01x
A6 (C7 Platform) Discussion
Aug 25, 2023 07:44 AM
Jeanna
Q7 MK 1 Discussion
May 23, 2023 06:30 PM
Jeanna
Q7 MKII Discussion
Feb 21, 2023 07:31 AM
Anthony Ferguson
Q7 MK 1 Discussion
Jul 12, 2020 03:45 AM
