VAD Discussion
A/C
Old Sep 8, 2019 | 10:05 AM
MotorMark!'s Avatar
Default A/C
Any thoughts on the remedy for an Mk II TT A/C that blows strong and cold upon start and turns to an almost non-existent stream of air after about 1/2 hour? Thus far when this occurs it is sunny, will happen in auto or manual settings and although hardly any CFM of air is coming out the vents, what does is cold. Also if you manually adjust the blower motor speed you can hear it wind up and down just nothing coming from the vents. It is as though the system has closed off all doors to the vents. BTW, this started last year and was diagnosed by Audi as a failed sun sensor which was replaced. How likely is it that I received a faulty new OEM sensor? Any thoughts are much appreciated.
old96A4
Oct 30, 2011 03:36 PM
mileRUMA
13
Jan 16, 2009 05:04 AM
Tomasz@Startup
Jun 25, 2004 02:38 PM
Meigwen
Audi 100 / A6 (C4 Platform)
Aug 22, 2003 07:16 AM
Mr. fix-it
Feb 2, 2003 02:47 AM
